Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8n still has problems
ericlb
07-26-2014 06:27:36
one other thing i will mention as it happened to me, is check the float level, if its not droping enough you wont have enough gas to run out the float bowl when the engine is running, and you wont have much power under load, as its simply leaning out, push it hard and it will quit running, i have a farmall that did exactly this after i rebuilt the carb, the float level was ok, but the float drop was almost nothing,it would idle and run by itself ok, but ask it to do some work, and it would shut down in a minute or so, i adjusted that and its unstoppable now
Copyright © 1997-2015 Yesterday's Tractor Co.
