Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8n still has problems
JMOR
07-25-2014 19:02:41
Quoting Removed, click Modern View to seeLooks like you have identified the problem in, "Still no gas flowing from the carb when it is running and I remove the drain plug on the bottom." Now to find the why. Tank venting, in-tank filter, sediment bowl valve & passages in same, sediment bowl screen, line, elbow screen at carb inlet, carb path to needle valve, needle valve/float assembly, and finally the two small holes(only right hole can be seen in picture) connecting the bowl to the bowl drain plug.
[URL=http://s192.photobucket.com/user/JMOR_photo/media/carbs/mainjet_nozzle_hole.jpg.html][/URL]
[URL=http://s192.photobucket.com/user/JMOR_photo/media/carbs/3_Fuel_Filters_Gary_MT_2.jpg.html][/URL]
[URL=http://s192.photobucket.com/user/JMOR_photo/media/carbs/Sediment_bowl_passages.jpg.html][/URL]
TexasCowboy
07-26-2014 05:50:50
 Re: 8n still has problems in reply to JMOR, 07-25-2014 19:02:41
Yep, all them parts and holes are clean. Actually, mine are a lot cleaner than the ones in the pictures.
My next test is going to be a compression test to determine why plugs 3 and 4 get fouled and wet. Plugs 1 and 2 don't, so I can eliminate everything not engine related.
I am also going to put hotter plugs in to help with this problem.
I suspect the reason I wasn't getting flow from the bowl drain is because I had the tractor running faster than an idle.
