Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
‘50 8N Hyd. Lift Piston Part Question
fostersfarm
07-25-2014 09:58:09
Rebuilding lift. Converting to NAA piston. The clevis pin that connects the connecting rod to the ram arm was damaged so want to replace. It is either not listed or CNH and online sites state “Ford 8N Pin, Procure Locally, Pin, Clevis, Connecting Rod to Ram Arm, 5/16" x 2-1/8", Years: 01/01/1939-12/31/1952 ..” Found at local farm hardware store but no info on grade. Anyone with grade requirement or where to buy?
Thanks, Foster
mhb@ufe
07-25-2014 10:05:25
 Re: ‘50 8N Hyd. Lift Piston Part Question in reply to fostersfarm, 07-25-2014 09:58:09
You don't need to worry about grade as it just holds the rod in place as the end will press into the socket under load.
Mark
fostersfarm
07-25-2014 10:09:44
 Re: ‘50 8N Hyd. Lift Piston Part Question in reply to mhb@ufe, 07-25-2014 10:05:25
Thanks, Mark
soundguy
07-25-2014 13:30:06
 Re: ‘50 8N Hyd. Lift Piston Part Question in reply to fostersfarm, 07-25-2014 10:09:44
ditto.. retainer / locator only. carries no load.
Copyright © 1997-2015 Yesterday's Tractor Co.
