Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: No power to starter switch
07-25-2014 07:00:37
If you are talking about the original safety interlock switch on the trans cover, it should not have power on it.
The switch supplies ground to the solenoid. The solenoid is ground activated and "hot" at all times. you simply complete the circuit by applying ground to start it.
07-25-2014 14:26:08
 Re: No power to starter switch in reply to JCinKY, 07-25-2014 07:00:37
JC, you are absolutely right saying the switch provides ground to
activate the solenoid, but if the solenoid were good, you should
read battery voltage on the small wire to the switch until the
switch is pressed. Minor detail I know, but it helps when testing.
