TractorLinks.com
Order Ford 8N Parts Online
Re: 8n timing question
oldtanker
07-25-2014 06:34:16
Not enough info. What's it doing while you are timing it as far as RPM's? Steady, slowing increase/decrease while turning the distributer, surging?
If it's steady I'd check the distributer or in/decrease again the dizzy. If it's surging figure out what's wrong and go from there.
Rick
cbradio
07-25-2014 06:37:10
 Re: 8n timing question in reply to oldtanker, 07-25-2014 06:34:16
Bounces high bounces low, bounces to the desired set point, bounces low, bounces high, repeat random bouncing
Bruce (VA)
07-25-2014 06:49:27
 Re: 8n timing question in reply to cbradio, 07-25-2014 06:37:10
I'll ask my question again:
At what RPM?
There are three settings.
cbradio
07-25-2014 06:53:49
 Re: 8n timing question in reply to Bruce (VA), 07-25-2014 06:49:27
All rpms, idle med low. It never stays at 4 degrees if it is supposed to be 4 degrees. It constantly bounces hi and lo
Bruce (VA)
07-25-2014 06:55:54
 Re: 8n timing question in reply to cbradio, 07-25-2014 06:53:49
Any performance issues?
cbradio
07-25-2014 06:58:52
 Re: 8n timing question in reply to Bruce (VA), 07-25-2014 06:55:54
I was having a clogged carb issue due to grit from new gas tank but it did this before I changes tank and after I cleaned the carb. I am currently installing new water pump and radiator,so I won't be able to check again until that is complete
