OT: Where to get replacement blades, Ford 951A
pdhntr
I have a 60" Ford 951A Rotary Mower and would like to replace the blades on it.
Is there a place that has replacement blades that I can order from on the web?
Thanks.
Jim
pdhntr,
I buy my rotary cutter blades from a company called Agri Supply. All you need is the blade measurements, length, width, mounting hole size, etc. That"s what I use to match them up. Agri-Supply is about half the price of anyone else.
agrisupply.com
HTH,
Roger
(quoted from post at 15:07:05 07/24/14) pdhntr,
agrisupply.com
HTH,
Roger
Hi Roger,
I was hoping I could order by application so I didn't have to pull one off, but it probably sounds like I am whining so I will get at it and get the measurements.
Actually, I should get the measurements just to make sure I get the right ones, even if there is an application guide.
Thanks for the info.
Jim
Have you tried CNH? Their website lists them at ~$182 a pair.
A quick Google search on the part number shows them at
Messick's for ~$183.00 a pair. Sounds high to me, but at least
its a part number if it matches what you have.
(quoted from post at 20:15:43 07/24/14) Have you tried CNH? Their website lists them at ~$182 a pair.
No I haven't tried CNH or Messick's as I have never heard of them. That is why I posted the question as you guys (the Yoda's of all things tractor) know these places, I don't. :D
So what is a "BMB"?
I will do a search of the places, however, I agree with you, the price is high. At that price I can do a lot of welding and grinding to save the ones I have.
Thanks guys. You have provided some good contacts for me to research.
Jim
