I purchased new spindles for my 2N. Problem is the groove for the bolt is directly opposite (180 degrees) the slot for the woodruff key. My spindle arms (2N 3130 and 2N 3131) have the bolt slot about 150 degrees around and not directly opposite (see photos). As such the bolt won't go through.
The retailer checked their stock and all their 2N spindles are this way.
I could buy 8N arms (at more cost) and convert. The tie rods are the 2N style. Any problems with going this route?
I could return the spindles and simply re-use the old ones. The left has a bit of play at the top, perhaps less than 1/32" between it and the bushing all around. The right has a little less play but its play is at the bottom. Is this much play within 'tolerances' or should I be tighter? If so;
I could return the spindles and have a machine shop install another thicker bushing made for the top left and the spindle built up a little on the lower right.
I could have a machine shop re-do the grooves by adding metal and regrinding.
What experience and recommendations do you all have in this case? Itching to get the tractor running again to shred the back 5.
Thanks for your help.
