hairline crack in head, can it be repaired?
dogsled1
I have a '52 8N that I am trying to get going. It has been sitting up for about 3 years. The previous owner pointed out a hairline crack in a water passage on the head, said it oozes coolant when hot. I have read a few posts where people have managed to fix this with metal shavings (a rust repair) and some folks claim that JB weld will do the trick. I was hoping to get some first hand feedback here.
Is it worth trying to fix? A quick search yielded both new and remanufactured heads starting at $125.
If it was mine I would replace it. If you got lots of time and like playing with it you could try and repair. I brazed a cracked block years ago and it held, but it is always a crap shoot!
dogsled1,I would look around for a good used one ,ebay,Local ect.$50.00 $60.00.Then you know it's repaired.
Perhaps, but for the price of a good used head, it's hardly worth the effort.
I tried brazing leaking pin holes in an N head 25 years or so ago without success.
Dean
Get a good used one. When you are bored in the winter have
it welded and keep it as a backup. You can never have too
many spare parts.
If it was mine, and I hadn't pulled the head yet, I'd be tempted to
throw in a can of Bars Leak and see what happens. If nothing else it
might give you some time to find a good head at your leisure, at
best it might fix semi-forever.
for the low price of a N head. I'd get a good one.. then braze the old one after cleaning it up good.
use it as an emergency spare...
i for sure would not use jbweld...
Braze would be the safest concerning warping IMHO.. though I certaintly think it could be welded properly too.
(quoted from post at 19:29:46 07/22/14) for the low price of a N head. I'd get a good one.. then braze the old one after cleaning it up good.
I agree with braze being a very good fix as well. (Welding engineer)
Welding on cast iron is a PITA. It requires specific preheat and interpass temps. Solidification cracks are a buzz kill.
I like that idea, I think I'll try that once I get it running and hopefully give me time to find a good used head. Since this tractor was free and has lots of unknowns still, I am trying to keep the investment to a minimum until I see how it runs.
(quoted from post at 22:44:10 07/22/14)
(quoted from post at 16:57:51 07/22/14)
Could the braze be done with a small plumbers torch? I have a small one that uses mapp gas and an oxygen cylinder.
Brazing can be done with Mapp gas and oxygen.
Shoot, you can weld with it if you're not doing thick material.
I can't vouch for how well it would work on a cast head, but
I still think it would work better than epoxy, JB Weld, etc.
