8n PTO shaft
Rodeo man
I recently bought an 8n. The PTO shaft appears to be covered by another PTO shaft. My eyes may be deceiving me, I'm not sure. Either way my bush hog will mount to it. Is this standard?
(quoted from post at 04:18:33 07/20/14)
(quoted from post at 05:36:51 07/20/14) maybe an overrunning clutch
The PTO stops when I push the clutch in.
No an over running clutch is an extension that mounts onto your rear PTO it is used for things like a brush hog. It momentarily disconnects your rear mounted implement from your rear PTO so the inertia caused by the rear implement doesn't keep forcing your tractor to move forward.
Just Google over running clutch or ORC
" I recently bought an 8n."
Check out tip # 39; a set of manuals will be a great help to you.
Take a pic & post it; they will help all of us trying to ID the attachment.
The pic is of a PTO adapter.
As greywolf suggested, Google over running clutch & see if that's what you have. (and it probably is)
75 Tips
You can post direct here! when making a post scroll down to where it says upload photo and follow the directions. Not sure what the size limit is but you may have to resize them if they are too big.
