My 43 2N came without a air filter so have been running a couple layers of window screening on choke horn to keep the large stuff out.
3 weeks ago I finally installed a filter and haven't even started her since. Yesterday while doing something else I realized the throttle doesn't move through it's ranges because the filter is touching throttle rod as well as choke rod. Filter is also not centered in hood dimpled area, it's about 1" forward of it. It is also only about 1/8" from hood.
My question is was there a adaptor that relocated the filter backwards and out a small amount?
There are no exploded views in my FO-4 showing the mounting.
All I had while putting filter on are the square holes in battery platform (for carriage bolts?).
