What to check with hyd intake ex valves on 8n
Cochise
New User
Got my top cover off to try to figure out an issue. how do I check the intake and exh valves. I can feel spring pressure on the intake at the last part of the movement,just before it touches the pump housing. Its pretty clean inside and don"t know if its worth pulling the pump for more cleaning. Thanks.
My lift touch lever kept going further down until the point where the guide was open and the lever was pointing straight down ,the three point is either all the way up or down. No in between.
