NAA carb ID
Money Pit
time to get my carb cleaned up and want to have the parts on hand before starting. simple question: how to identify the carb model i have? thanks.
[b:e04aca2a7c][i:e04aca2a7c]
M..P...;
Need more info. to find out what carb. you have!!??
Make of carb....Marvel Schebler, or Zenith?
Year of NAA? Engine ser#
size of engine?....134CI, or 172CI
Actual NAA..Jub,...or ????
OR......post a couple of pix of yer carb.!
Gary :?: [/i:e04aca2a7c][/b:e04aca2a7c]
(quoted from post at 09:50:58 07/18/14) thanks Gary. i'll get some pics over the next few days; seems the easiest.
b:365df794f9][i:365df794f9]
Here is what the OEM M/S carb should have on it.....:
A staked-on brass tag, with the letters...TSX and the #of the carb.......(outside of the carb, by the choke horn area)
An aftermarket Zenith....will have a stamped tag, with the carb #, attached to one of the half-shell hold-down screws.
If NOT.....Its anyones guess, as to what carb you are working with!!!!
Gary :roll: [/i:365df794f9][/b:365df794f9]
