Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
8n Tranny questions
Ed Douglas
07-17-2014 09:32:31
Hello Forum Chums,
Bought a Tranny years ago....the price was too good to pass up. A guy was parting out a a really tight steering box as also.
Getting to work on the 8n high crop conversion...and the tranny in it has 2nd gear off the replacement tranny ...the gears look pristine....everything nice and the bad had sat for so long ....throw out bearing would not move......PB blasted my brains the fork rod to finally move with a 3 foot pipe wrench.....oh the fun was just getting started...turns out that this tranny had an early 48....or late 47 had to remove the have no idea how stubborn that little pin was to leave its to split the tractor.....retrieve my newer linkage...and go to town....finally to the questions.....while everything is broken down.....any considerations other than to replace the main front shaft seal??......should I replace anything in the PTO assembly?...seals or bearings??...any other thoughts or pitfalls from anyone who has been here??
07-19-2014 05:03:57
 Re: 8n Tranny questions in reply to soundguy, 07-17-2014 09:32:31
The only difference is I shim the bearing race because the shims are hard to come by,,, Good ones anyways.... It all works out the same in the long run....
07-18-2014 11:37:27
 Re: 8n Tranny questions in reply to Ed Douglas, 07-17-2014 09:32:31
If you have the trans out you could get a general idea of the condition of all the bearings by removing the bearing retainers one at a time looking at the race and the bearing rollers... NO complete disassemble needed... The counter shaft my drop all you would need to do is run a wire around it and pull it up to install the retainers back in place...
Ed Douglas
07-18-2014 22:16:09
 Re: 8n Tranny questions in reply to Hobo,NC, 07-18-2014 11:37:27
Hey Hobo,
Saw on another post you had a Sherman for sale.....what is involved in the install process?....maybe I could find it a new home
Ed Douglas
07-19-2014 14:03:22
 Re: 8n Tranny questions in reply to Ed Douglas, 07-18-2014 22:16:09
Hey Hobo....give me some good contact info.....cell and a good email the idea of the
Thanks, Ed
Ed Douglas
07-17-2014 20:00:29
Follow up.......I know you can get the original clutch resurfaced....but pressure plate.....can they be "gone over"....seems like the original may be better than aftermarket made God knows where.... thoughts??
07-18-2014 04:52:36
 Re: 8n Tranny questions in reply to Ed Douglas, 07-17-2014 20:00:29
You have the parts in hand, so you are the best judge.
Most will recommend replacing everything, and they are right of course. But, I don't like new parts and I'm cheap.
So, if the PP works, with all its springs, fingers, and pivot points intact, with good spring pressure, it gets cleaned up and goes back in. Flywheel too. Time and wirebrushing/sanding.
couple examples, 54 NAA from a fencerow, engine stuck, all clutch components stuck and completely full of nests. mess.
another, 75 loader 5000 with a leaking freezeplug on the back of the block...for years...real mess.
Both got a new clutch disk and throw-out bearing,
all other parts cleaned up at home.
Both work fine now.
Seal leaks? I fix it. If one doesn't leak, you couldn't pay me enough to touch it.....
disclaimer, I'm not an on the clock pro, so my time is free on my stuff,
and splitting doesn't bother me (taking money out of my wallet does), unhook some stuff and take out some bolts and pull it apart and then reverse the process.
It really is that easy, just have to cover all the 'what-ifs' so ya don't get squished.
(that loader equipped 5000 was a bit heavy :) )
If it bites me someday and I have to split be it.
R Geiger
07-17-2014 15:28:34
 Re: 8n Tranny questions in reply to TOM N MS, 07-17-2014 09:32:31
If it was mine, I would completely disassemble the trans and check the bearings to make sure none of them are pitted from setting so long! It is really not that much of a job!
07-17-2014 14:49:15
if the bearing is good on the pto.. leave it. seals? i repalce them if I can get at them easilly and I don't know their age.
Ed Douglas
07-17-2014 15:09:30
 Re: 8n Tranny questions in reply to soundguy, 07-17-2014 14:49:15
What about the throw out bearing Soundguy......seems fine!
07-17-2014 15:32:08
 Re: 8n Tranny questions in reply to Ed Douglas, 07-17-2014 15:09:30
Cost vs labor.. I tend to always replace tob's when split
