Temp gauge adapter
KennyMac41
New User
I am installing this on a 49 8n. Are any photos available on a complete install? I assume the adapter would be installed in front of the thermostat?
Yes, Like Hobo said. What type adapter are you putting on it? Why not use the flat spot on the head that was made for a sending unit? That's were you will get your best reading.
(quoted from post at 13:55:16 07/15/14) Yes, Like Hobo said. What type adapter are you putting on it? Why not use the flat spot on the head that was made for a sending unit? That's were you will get your best reading.
Wasn't aware there was a place on the head. The adapter I purchased is from Yesterday, fits in the upper hose, clamped on both ends, Metal pipe type with fitting for the sensor
