Anonymous-0
Does the transmission need to be removed from both the engine and the rear end to be disassembled? I believe that the spline on a gear of the main shaft are failing.
Unless some one has another opinion. When the tractor is in first gear with a load on it when you ease off the clutch the tractor will start to move and then it will pop and roll backwards then thy to do it again. With out a load it is fine second gear is also fine.
Last the ring and pinion broke while in first gear and locked the tractor up, I believe this also broke the transmission, but I can not see any damage leading me to think it is the spline on the main shaft or inside a gear.
