Hi - on the weekend I was helping a friend with his 9N - it's a 12 v conversion, front mounted distributor. Basically the machine would crank but not start - though with a pull start it ran like a top. Here's what I've checked so far:
- battery was undercharged - that's being corrected
- no spark so I traced back to find the ballast coil side dead - getting a new one
- haven't checked the alternator charging but given the state of the battery I suspect it was not charging
- haven't put the multimeter on the coil yet
So some questions:
- once I get the ballast and have the battery charged is there a particular order of checks or prodedures to diagnose what went wrong ?
- if the coil or alternator are fried is there a root cause to correct
Thanks in advance
Steve
So some questions:
Thanks in advance
Steve
