Leaking seal
On what model tractor?
A drawbar goes between the lift arms. Lift arms attach to the differential housing.
Do you have a leak where the lift arms attach to the differential housing?
75 Tips
There is no seal there. To fix to it, you need to remove the axle trumpet. If you remove the left trumpet, you can do them both at the same time. The pin is held on by a castelated nut w/ a cotter key on the inside. Drain the fluid (see tips 3 & 4, below) Remove the left trumpet & slide the differential gear out. (an engine hoist is a good idea) Make sure the holes are not wallowed out or you will be in there again. I hear JB Weld works, but I've never had the problem so I can't say for sure. Torque the nut on the new pin to 150 lbs before you put the cotter key in. Wipe the new trumpet gaskets w/ warm water & let them set a few minutes before you put them on. Make sure you use your favorite gasket sealer. Torque the 11 trumpet studs to 40 lbs.
Check out tip # 39; a parts catalog would be helpful for this repair.
75 Tips
Bruce, 150 lbs/ft or lbs/inch? I presume lbs/ft. Gonna need more tools ~grinz~
I have same issue on Sadie and 'hope' to get-er-done before winter sets in again.
Thanks, Norm
