TractorLinks.com
Show Parts for Model:
alternator belt length
Mike Murphy
07-08-2014 16:28:00
When I bought this 1946 2N tractor the alternator belt was the wrong length. Does anyone happen to know what's the right length of belt.
Charner MS
07-09-2014 14:22:28
 Re: alternator belt length in reply to Mike Murphy, 07-08-2014 16:28:00
The fact you own an 8N means you are on first name basis with the parts guy. He may let you take an 5/8' 40 - 42 - 44. One of these surely fits. Return the other ones.
willie in mn
07-09-2014 00:28:20
Quick & dirty. The belt will be destroyed, but it is wrong size, so not a great loss. Being that the belt was installed, it apparently is too long.
Move the alternator or adjustment idler to the shortest position. Cut the belt. Pull the belt snugly into position & mark the overlap. You now have the correct length. Buy one that length, or the next closest longer.
Willie
Royse
07-08-2014 18:03:30
Find a piece of rope about the width of the belt, wrap it around
the pulleys the same way the belt would run then measure the
length of rope it took. That will get you pretty close.
Mike Murphy
07-08-2014 19:19:19
 Re: alternator belt length in reply to Royse, 07-08-2014 18:03:30
Royce thank ya
Bruce (VA)
07-08-2014 17:41:38
" Does anyone happen to know what's the right length of belt. "
That's hard to say because N's didn't come w/ alternators. The belt length would be determined by the length & placement of the mounting bracket.
That being said......a good starting point would be the OEM belt length for the generator; check out tip # 75 at the link.
Mike Murphy
07-08-2014 19:17:43
 Re: alternator belt length in reply to Bruce (VA), 07-08-2014 17:41:38
Thanks Bruce
