TractorLinks.com
Order Ford 9N Parts Online
Re: 9N no start
soundguy
07-08-2014 16:25:35
as said. popping is usually arcing.. meaning bad connections.
now. are you still using the mechanical start switch.. or a solenoid?
Guardian3
07-09-2014 08:59:56
 Re: 9N no start in reply to soundguy, 07-08-2014 16:25:35
I am using the mechanical start switch. I have totally rewired this tractor 2 years ago and have not had any issues. When I split the tractor to replace the clutch, I only disconnected the battery and wires going forward toward the engine. I have checked and tightened all the wires and don"t see any signs of arcing. I pulled the start switch yesterday and it appeared the switch was stuck in the "start" position, so I worked it back and forth and got some penetrating oil on the plunger so it would release better. I am recharging the battery and will test later today. I did notice the battery cable on the positive terminal was very hot, so I am hoping it was from the start switch staying engaged. That would also explain why the tractor tried to start when I was reconnecting the starter.
