TractorLinks.com
Order Ford 8N Parts Online
Re: What is normal for a FOrd 8N?
TOM N MS
07-08-2014 10:29:54
Drain hyd fluid from rear sump or nose it down in a ditch to make the fluid run forward(Caution: if front tranny seal is bad u will soak your clutch like I did then I had to replace the clutch) I remove the pto shaft to gain a tiny bit of working room inside..I work from the left side(remove the plate with the pto engage/disengage lever) Use 11/16" boxed end/open end wrench--I use standard wrench-some folks cut and bend wrenches....unscrew old one and screw in new one..tiny strokes usually involved but once broken loose, you can normally reach in and finish removing by hand...HTH
