Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: What is normal for a FOrd 8N?
John Ayres
07-08-2014 09:00:04
Thanks to all on this. Since the piston and seal were replaced and it stayed the same I am inclined to suspect the pressure relief valve. Tip 16 does not address the procedure to replace this. Is this a complicated job?
Bruce (VA)
07-08-2014 11:42:32
 Re: What is normal for a FOrd 8N? in reply to John Ayres, 07-08-2014 09:00:04
" Since the piston and seal were replaced and it stayed the same I am inclined to suspect the pressure relief valve."
Excuse me, but you are about to make the same mistake twice in a row.
There is a reason why I asked these questions:
How did you determine the lift cylinder/piston was bad?
Did you observe the oil leaking down from the top?
Did you check for a leaky pressure valve?
The point of tip # 16 wasn't to tell you HOW to fix the problem......but to tell you to DIAGNOSE the problem BEFORE you start replacing parts.
It's not that hard to pull an inspection plate & see if you oil leaking down from the top w/ a load on the arms. You wouldn't be the first guy to replace a cylinder in a bad piston. Or failed to detect a blown gasket w/ an internal leak.
If you do not see oil leaking down from the top, then test the pressure relief valve before you spend time & money to replace it. Because there are still other causes of the problem.
TOM N MS
07-08-2014 10:29:54
Drain hyd fluid from rear sump or nose it down in a ditch to make the fluid run forward(Caution: if front tranny seal is bad u will soak your clutch like I did then I had to replace the clutch) I remove the pto shaft to gain a tiny bit of working room inside..I work from the left side(remove the plate with the pto engage/disengage lever) Use 11/16" boxed end/open end wrench--I use standard wrench-some folks cut and bend wrenches....unscrew old one and screw in new one..tiny strokes usually involved but once broken loose, you can normally reach in and finish removing by hand...HTH
