Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Is 2875 RPM too much?
ratface
07-08-2014 08:20:18
Since replacing my worn throttle plate and making lots of adjustments I finally got the throttle lever to behave pretty good in each quadrant. The tractor now idles nice at low Quadrant with good upsurge of power on the last quadrant of the face plate. I remember reading that the max RPM is 2600. My tractor is topping out at 2875 rpm, throttle lever all the way over. Is the 275 rpm that big of deal, quite frankly I kind of like it?
ASEguy
07-10-2014 04:16:57
 Re: Is 2875 RPM too much? in reply to ratface, 07-08-2014 08:20:18
Seems like a simple question to answer. If it was an engine in good shape probably not. On the other hand if it's worn out I wouldn't take my old tractor engine that high because it can cause additional ventilation as JMOR stated.
Tim23
07-08-2014 15:57:52
Wow, I usually operate at 540 rpms at the pto which is idk, about maybe 1400? I really don't like to go much higher than that, it sounds like its gonna take flight. I don't really know what I'm talking about, but N's don't have harmonic balancers right? Isn't that the reason for the lower rpm range, the engine will shake itself apart?
What about the pulley ratio? Is it 1:1
This post was edited by Tim23 at 16:00:20 07/08/14.
Hobo,NC
07-08-2014 14:06:35
If you can hang on and stay in the seat its not to much.... The gov gear came lose from the shaft on one of my N's it took off like a rocket... I was almost done but it was not EZ to manage the extra un-governed power... The gov keeps it manageable at most any speed..
R Geiger
07-08-2014 11:40:26
 Re: Is 2875 RPM too much? in reply to mhb@ufe, 07-08-2014 08:20:18
Quoting Removed, click Modern View to see Thanks, I learn something every day. The motor had a light load on it!
R Geiger
07-08-2014 10:34:12
 Re: Is 2875 RPM too much? in reply to gwstang, 07-08-2014 08:20:18
I put the tape on the crankshaft nut and as close as I could tell I was getting a bit more than the tack. I only get a bit over 2000 RPM at max and that works for me.
The I put some tape on a 1725 RPM electric motor and I was getting about 1755, so it looks like mine is a bit high. Harbour freight special.
Jim WI
07-08-2014 11:28:08
 Re: Is 2875 RPM too much? in reply to R Geiger, 07-08-2014 10:34:12
The 1725 rpm on the electric motor nameplate is at full load. The actual speed decreases as the load increases. 1800 rpm is the synchronous speed of your motor, so 1755 rpm doesn't sound unreasonable if it is lightly loaded (or no load at all).
R Geiger
07-08-2014 10:11:28
Checking you device with a known RPM is a good idea. I think 2875 would sound way high for a 8n. I got one also think I will go and check my 50 that has a tack on it.
Duner Wi
07-08-2014 09:49:03
In 1942 when the tractor engine was available in pickups it was rated at 40 gross HP AT 3200rpm.
The valve springs were 9N also but cam had a different # as it had a fuel pump drive lobe.
4.55 would be standard gear in 42 for that engine.
ratface
07-08-2014 13:06:15
 Re: Is 2875 RPM too much? in reply to Duner Wi, 07-08-2014 09:49:03
So that same engine is capable of 3200 rpm? Which is really what I'm after, which is at what point does some damage occur?
Angus Thom
07-08-2014 13:41:55
 Re: Is 2875 RPM too much? in reply to ratface, 07-08-2014 13:06:15
<at what point does some damage occur?>
Typically about 1 second before you hear it. Just time for you to say "Oh dear, that's not good". (or words to that effect).
This post was edited by Angus Thom at 13:42:51 07/08/14.
JMOR
07-08-2014 15:32:28
 Re: Is 2875 RPM too much? in reply to Angus Thom, 07-08-2014 13:41:55
Quoting Removed, click Modern View to see....and if hard of hearing, they sometimes give a visual:
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Engine/hole_in_block_2.jpg.html][/URL]
JMOR
07-08-2014 13:11:07
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Engine/HP.jpg.html][/URL]
Bruce (VA)
07-08-2014 08:26:30
Max RPM is supposed to be 2200 RPM, not 2600.
I'd question your tach.
As long as you have good oil pressure, I wouldn't worry about.
JMOR
07-08-2014 08:23:52
On what tractor??
Bruce (VA)
07-08-2014 08:27:27
 Re: Is 2875 RPM too much? in reply to JMOR, 07-08-2014 08:23:52
Duhhhhhh.......
Good point! 2200 rpm is for an N.
ratface
07-08-2014 08:35:55
 Re: Is 2875 RPM too much? in reply to Bruce (VA), 07-08-2014 08:27:27
It's a 1949 8N FM. The Tach is one of those hand held point and click Tach's with a piece of reflective tape on the fan housing. Is 2200 at idle?
Bruce (VA)
07-08-2014 08:46:13
 Re: Is 2875 RPM too much? in reply to ratface, 07-08-2014 08:35:55
" Is 2200 at idle?"
You're kidding, right?
2200 is max rpm.
It should idle below 500 rpm; 400 is the goal.
ratface
07-08-2014 09:56:52
 Re: Is 2875 RPM too much? in reply to Bruce (VA), 07-08-2014 08:46:13
2875 is max RPM, I didn't measure the low side. I will do that next time I can work on it. The gizmo for measuring is pretty cool, just point and click. States the margin of error is +- .05%. I think I will measure a known value to see if this thing is accurate. The tractor just sounds right where it's at. Your point about low rpm is well taken, perhaps it's too fast from the git-go. I've fooled with so many adjustments I might not have put the idle screw back to where I started?
Roger in Iowa
07-08-2014 16:43:58
 Re: Is 2875 RPM too much? in reply to ratface, 07-08-2014 09:56:52
To check your hand held optical tach, point it at a florescent light. It should read 7200+or-, if your tach goes that high. Good way to check them.
