TractorLinks.com
Show Parts for Model:
Re: Loss of compression
Greg in SC
07-07-2014 19:32:33
OK I will look at that tomorrow. If the head gasket has an internal failure (I saw no external leaks) with a breach from the water jacket to the cylinder, shouldn't it suck water into the cylinder during the power stroke (both valves closed)? If there is a water passage into the cylinder, I should be able to crank s few cycles and swab inside the spark plug hole to test for moisture, correct? I know I will have to remove the head no matter what the problem is - I just want to go slow and check things before I do that.
Ultradog MN
07-08-2014 00:42:05
 Re: Loss of compression in reply to Greg in SC, 07-07-2014 19:32:33
Yes you could do that though it's a bit of extra monkeying around.
Another way to check would be to fill the radiator real close to the top and look inside for bubbles when it's running.
A real bad head gasket leak will blow a lot of water out of the radiator.
