Danny in CO
I have a 97 Escort 2.0L. It recently stop charging. I had the alternator checked and it was bad. I replaced with a new one. It still wouldn"t charge (the dash battery light is on). I had the battery checked. It was marginal. I replaced it and changed the battery terminals. Still didn"t charge. I thought the wiring connectors at the alternator might be bad. I got another harness at a junk yard and splice into the old wires. Still doesn"t charge. I had the new alternator checked. It checked out good. I also swapped it with an alternator from a 99 Escort I have. The new alternator works good in the 99 Escort and the swapped alternator doesn"t work in the 97 Escort. All the connections are good (I think). I"ve checked them at the battery. Are there any fuses or relays in the circuit? I haven"t been able to find any.
I"m at a loss now. Any ideas where I should look next?
Thanks,
Danny
