transmission oil ?
swpaguy
Would you put this in your tractor? Says it meets fords standard for the n series. Only reason I'm considering is its available local.
http://walmart.com/ip/Super-Tech-Heavy-Duty-Tractor-Hydraulic-and-Transmission-Fluid/16213442
(quoted from post at 12:47:05 06/29/14) Would you put this in your tractor? Says it meets fords standard for the n series. Only reason I'm considering is its available local.
It is fine and "yes" I would put in in any of my tractors.
TOH
As long as it meets that Ford Spec yes, but WalMart isn't always
the cheapest place to get it. Look around at your local farm stores.
Sometimes they run it on sale for less here.
Royce I agree with you. Few weeks back I bought a 5 gallon bucket of hyd. fluid for my splitter at Wallyworld only to go to TSC an hour later to buy some hyd connector and saw the same type of 5 gal. hyd fluid for $8 cheaper. Almost paid for the connector I bought.
