TractorLinks.com
Show Parts for Model:
Dist test
WW2N
06-23-2014 14:36:28
Anyway to test a 8N side mount distributor other then putting it in a motor. I got a backup dist at a swap meet. I dont want to take the ones out of my running Ns.
Royse
06-23-2014 18:23:05
 Re: Dist test in reply to WW2N, 06-23-2014 14:36:28
I would spin it slowly.
Not easy to measure accurately spinning it too fast.
WW2N
06-23-2014 17:22:10
Thanks guys, I did put new pts cond the cap and rotor looked good. Ill chuck it in my 1/2 drill and spin it. LOL
Ultradog MN
06-24-2014 12:02:02
 Re: Dist test in reply to WW2N, 06-23-2014 17:22:10
You don't need to spin it.
Turning it back and forth 1/4 turn would make it spark if you had the rotor pointed to the correct test plug wire.
Ultradog MN
06-23-2014 15:59:24
You could put put points, rotor and cap on it then rig up a coil, battery, wire and spark plug to test it. Just spin it by hand.
I don't know what the spec on bushing wear should be but that could be checked with a dial indicator or a guy can feel/see .005-.006 thou pretty easily.
Bruce (VA)
06-23-2014 14:38:51
You can test for continuity w/ a meter.
But it really needs to be in the tractor to check for bushing wear.
