TractorLinks.com
Order Ford 9N Parts Online
9N trans input shaft + a clutch/flywheel install question
Brian R B
06-23-2014 12:34:20
My 1941 9N has a differently designed input shaft bearing retainer for the transmission (I think that is what it is called) from the one shown in the F04 manual. The gasket which I got from Ford New Holland is smaller than the original and has ears on it, while mine is square and larger. Also, there are roller bearings on the shaft, not what appear to be tapered bearings in the manual, and a snap ring/C-clip on the shaft, again not shown in the manual. (The seal from Ford New Holland does fit, and I have replaced my tattered original.) The input shaft, which I wanted to use to align the clutch when I put the tractor together, will not come out, without I fear, battling that snap ring. Years ago, in an engine rebuild, I put the clutch back on and reassembled without an alignment tool or the input shaft. Dumb luck? Question, is eyeballing the clutch or some workaround a viable option (still) for clutch reassembly or should I get the 7.00 alignment tool (and probably never use it again)?
Brian R B
06-24-2014 07:09:36
 Re: 9N trans input shaft + a clutch/flywheel install question in reply to Brian R B, 06-23-2014 12:34:20
Sherman step-up it is. I never knew about such a thing! I'll either get the tool or fabricate somethins, BTW.
John Smith8N
06-23-2014 17:54:45
 Re: 9N trans input shaft + a clutch/flywheel install questio in reply to Brian R B, 06-23-2014 12:34:20
Sounds like you have a Sherman step-up installed instead of the regular input shaft.
HCooke
06-23-2014 16:05:40
"should I get the 7.00 alignment tool (and probably never use it again)?"
Either that or disconnect the input shaft from the trans and use it. You should replace the trans input shaft seal while you are in there and you have to remove the shaft to do that. Then you could take a picture of this shaft and let us see it.
ASEguy
06-23-2014 15:52:34
I just did a split on a 2N and would suggest you buy the alignment tool. I've done a lot of car and truck clutches and it's nothing like rolling two tractor halves back together.
