NAA Clutch Replacement
CAC63
I am going to replace the clutch on my Ford NAA. What preventative maintenance would be good to do with the tractor split? Are there wear parts that are good to replace? How difficult is replacing a clutch?
throw out bearing, pilot bearing ( or bushing if it has the early flywheel ), trnas input shaft seal.. etc.. clean bellhousing drain.. make sure cotter pin is in place.. etc. inspect ring gear...
sg gave you his usual comprhensive list; all i can add is:
just did one a few months ago not that big of a job. splitting and putting back together are the biggest parts. i wheeled the back away from the front so i wasn't dealing with the front wheels wanting to turn.
biggest thing i had was the uncertainty of wheter my flywheel had the bushing or bearing. i don't think theres a way to know for sure until you get it split. ended up being hte bearing which came with the clutch kit.
