Oil Pressure Dont know if I have any
sparkybb63
New User
I purchased this 50 8N and the guy started it it ran etc etc.
Me being the new guy to tractors and all excited did not check the pressure gauge.
So after a few weeks of just getting it to start regularly I know have gotten to no oil pressure.
Is there a way to check if it is working or exactly what do I need to do?
Now I have noticed when turning over I hear a metalic noise....Pls say it is not bearings or something.
Should have made nickname takentocleaners :roll:
Thanks all
Also a big Hello to all
(quoted from post at 11:35:57 06/19/14) I purchased this 50 8N and the guy started it it ran etc etc.
Thanks all
asy. Plumb in a known good gauge or test your gauge against a known good gauge.
Loosen the oil line to the gauge - start it - if it
leaks oil you have pressure and need to replace the
gauge. If no leak, post back - will need to
investigate further.
(quoted from post at 08:35:57 06/19/14) I purchased this 50 8N and the guy started it it ran etc etc.
Hello,
Cheer up, maybe it's not all that bad.
If you didn't see blue, black or white smoke when starting or running, then you may still have a good enough working motor.
Get another good working oil pressure guage and do a test -- yours may be bad. Lets hope he didn't run it for a long time with super low pressure. Could be the oil pump itself is the culprit.
Noise when turning over is probably starter related so take the starter off and have a look for wear and examine the flywheel ring gear. Don't short out your battery cable when you disconnect the starter.
If everything checks out and the oil pressure is still too low then change the oil and put 20W50 in it -- unless you feel like rebuilding -- and that will increase your pressure and extend the life of old bearings with clearance so excessive that oil pressure is being lost.
Cheers,
Terry
Takeout the 15/16 plug on top of the timing? cover and fill with oil until it just runs out of the hole. Reinstall plug and see if that solves your problem.
This quick fix worked for me. I went from zero pressure on the guage to almost top of the green!
(quoted from post at 23:04:06 06/19/14)
Hi again, if you would not mind a bit of guidance. As really do not understand where exactly things are. Maybe in reference to distributor.
I did change oil and put finger in oil drain plug check tube and it is secure.
Disconnected line for where oil filter line goes into 2 way connector to check for oil flow and was zero.
Hi,
Are you wondering where the timing cover is?
If so, it is on the very front of the engine. The crankshaft end comes out to the crankshaft pulley (that drives your fan belt) through a seal in the timing cover. The timing cover covers the big timing gear on the end of the camshaft and a small gear on the crankshaft that drives that camshaft gear.
The piston strokes have to be coordinated with the actions of the valves driven by the camshaft; and so, the teeth of the crankshaft gear and the camshaft gear or sprocket have to be aligned tooth for tooth on assembly or the piston and valve movements won't be "timed". --hence, "timing cover".
According to the quick fix suggested above, there is a 15/16" plug on top of your timing cover that you can remove so as to fill the cover with oil -- completely full till it runs out, then put the plug back in as quickly as you can and start it up.
I guess the word "timing" got you thinking about the distributor where you time the spark.
Cheers,
Terry
(quoted from post at 21:51:06 06/20/14) Hi,
Cheers,
Terry
Thanks so much, it is what was my problem.
Sorry for delay as loads of rain and tractor is outside so was hard to finish.
I can not tell you how overjoyed I was when I seen the flow.
Felt like Jed when he shot the ground.
Anyway thanks again, now off to charging system.
