I have a 1947 8n. The top rocker has 3 holes set
in a triangular sort of pattern and a 3/4"
mounting hole. The previous owner used a 3/4"
bolt with a self-locking nut on each end to mount
the bracket to the rear housing. Pain in the
posterior. The outer holes on the rear housing
are 1" and the rocker has a 3/4" bushing. I see
that there is a long pin that was apparently
standard. Question is can I use a plain 3/4" pin
or should I remove the bushing and use a 1"? Also,
my unit doesn"t have the draft control spring
between the housing and the rocker. I just use it
on the rotary mower so don"t really need the draft
control function but wonder if it will cause any
other problem with it missing. Thanks y"all.
