8Nrear axle bearing
I had a rear axle bearing replaced on my 8N, I have it all put back together but now the hub will not turn, if I loosen the bolts just a little, then it will turn, every thing is installed correctly,,,shims are between housing and backing plate, correct? need help on this matter,,,could the retainer be warped/ some one help me please,,
It's hard to say without seeing it... the oil sealing setup changed over the years, and mis-matched parts could cause that as will a hub with worn splines that slides too far inward on the axle splines when the big nut is TIGHTENED.
My guess is you do not have the correct bearing preload.
I think on those you have to shim them to set preload.
Your manual should tell you how.
Others here will correct me if I'm wrong.
(quoted from post at 17:02:56 06/18/14) I had a rear axle bearing replaced on my 8N, I have it all put back together but now the hub will not turn, if I loosen the bolts just a little, then it will turn, every thing is installed correctly,,,shims are between housing and backing plate, correct? need help on this matter,,,could the retainer be warped/ some one help me please,,
an you turn the axle without the hub?
[b:3e8fd3c3ae][i:3e8fd3c3ae][color=darkblue:3e8fd3c3ae]"if I loosen the bolts just a little, then it will turn"[/color:3e8fd3c3ae][/i:3e8fd3c3ae][/b:3e8fd3c3ae] Kinda points toward improperly loaded bearings.
How did you adjust axle bearing preload?
Doubtful but not impossible to warp bearing retainer.
The paper gaskets (4229) are considered a shim as they do affect clearance. As shown in diagram, there is a shim between the trumpet and brake backing plate and between the backing plate and bearing retainer. I put one on the inside and the remainder on the outside of the backing plate.
thanks you all for helping me see what to do, I ordered some shims and gasket so now I can correct the load on the axle, again , thanks
