Front mount dizzy questions
BigDanT
2n front mount dizzy needed a little attention so I decided to give it a good cleaning and throw in some new bushings. Got to looking at the hole for the rear bushing and noticed it looked like it was drilled off center, is this normal, do I need to worry about it??? One other thing, either the PO or myself has messed up the front bushing mount so it looks like I'm gonna have to have new breaker plate, anyone had any luck with the new aftermarket ones? One site says "plate may need slight modification" WTH does that mean? Thanks Dan
As JMOR said, the base is fine.
" anyone had any luck with the new aftermarket ones?"
Yes.
They are junk.
These guys should be able to help you w/ used parts:
Jim Webb webbtractorATgmail.com.
John Smith smith8NATatt.net
Rod Mondor fltractorATpeoplepc.com
Replace the AT in the address w/ @
The money you will save can go toward a timing jig from TOH!
75 Tips
