throttle linkage adjustment govner ford 8n
When throttle is at idle govner has a rattle. when throttle is
moved forward 1/4. idle goes up and rattle goes away. do i
need to adjust linkage puling govner arm back
The governor needs to be shimmed internally per the shop manual so the cup/ball race can"t move rearward far enough to let the balls chatter and/or hit the governor case.
