TractorLinks.com
Order Ford 8N Parts Online
Re: 8n help 1st tractor wont start with new starter
Royse
06-16-2014 14:57:05
The only wires you need for the starter to turn it over are the
battery cables and the small wire from the thumb push start
button to the small terminal on the solenoid.
Assuming your tractor is wired as original.
If it is, the wire from the thumb switch goes to the small terminal
on the solenoid mounted on the starter and that small terminal
needs to be facing in toward the engine. Not out.
When you had the starter out, could you turn the engine over
with a big screwdriver on the flywheel teeth?
aarononeil
06-17-2014 02:36:01
 Re: 8n help 1st tractor wont start with new starter in reply to Royse, 06-16-2014 14:57:05
yes i could turn it over by hand. and those wires were correct. The solenoid clicks but is it possible that if the starter button wire were bad not enough power would go to the solenoid resulting in a no start scenario?
