TractorLinks.com
Show Parts for Model:
Re: Rim Straightening Table Jig
Tall T
06-15-2014 20:31:27
Hi Hobo,
You wrote:
"I never understood what you meant by custom rims but now I see they were hat rims that had been modified... Why any one would want wider rims I dunno it must be a man thang... I do and don't understand the gizmo but understand locking it down its haft of the battle so will wait for more pix (its a man thang)... "
I like the look of the wide tires and they do add a little weight.
I was just kidding pretty much about the jug. What happened was when I repaired the first rim I used a 2" thick round plate up on top of the heavy wooden box off my carry all. I did so much beating I was driving the thing apart so I decided I wanted a better surface and a slower curve to conform to the curved part of the rim needing the straigntening.
I've had this old Louisville stand thing from a laundry building in the 40's and I put a steel plate on it. There were two bolt holes tapped right through it and through the big plate. I just left it welded there for years thinking I might utilize those threaded holes somehow.
But wanting nothing around the edge, for the sake of rim-truing
and for a clear surface for other things, I proceeded to cut the welds to remove it but I had a heck of a time! I couldn't figure out why with all my cutting and banging chisels it would not let go. Close to exasperation I cut that small slab in half and the next time I beat at it with big hammer and chisel, the 1/2 plate turned!~!!
Well. . . as it turns out there were two threaded headless studs holding that 6" plate to the slab . . . BEFORE they fully welded it. So I managed to actually unscrew the two pieces from the top.
You wrote:
"I don't have a special gizmo so would use a punch bit in a air chisel and back off from the inside of the lip and let it lightly tap the lip back in place a little at a time,,, Tell you the truth I would not want that job..."
I've got that leveling gizmo at the back that I just put an outrigger on, so now I have a curved table top dolly under the lip that conforms more to the curve of the rim (and the rim is made to lay level) so it supports a larger area. It will be a breeze -- less work by eye, to straighten the second rim now.
Thanks for the visit,
Terry
