oil pan question
Since you posted on the N board I will guess you are talking about N N. The front axle support is bolted to the oil pan so yes you must remove the front axle. Just block under the front of the transmission to support the engine.
Mark
After removing the "pan", good time to check out the oil pump sump. Might need to be reinforced.
Simple solder job.
HTH
John,PA
