TractorLinks.com
Show Parts for Model:
Re: NAA quit running???
Royse
06-15-2014 15:47:43
If it fails again in the near future, check the wire between the
coil and the distributor/points. Where it passes through the side
of the distributor is a common failure point.
The insulation breaks down and it will intermittently ground out.
Changing the coil may have jarred the wire enough to un-ground it.
Foiles85
06-15-2014 17:36:55
 Re: NAA quit running??? in reply to Royse, 06-15-2014 15:47:43
Will do! That actually was my next plan to redo the wiring on it. That could have been a good possibility to it failing on me, as it appears the isulation is separating. Thank you!
