Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: NAA quit running???
Foiles85
06-15-2014 07:30:54
Ok checked the points and I have no spark. Is there any way it could be the coil or probably just the points? Just trying to check before I go into town. Thank you
Tall T
06-15-2014 07:56:04
 Re: NAA quit running??? in reply to Foiles85, 06-15-2014 07:30:54
The points would spark no matter how far gone they are if juice is getting to them -- maybe the coil to dist wire is at fault.
Then like the man said, test your ignition switch.
Pick yourself up a couple of little alligator clips and make up a jumper/test wire that you can clip to ignition terminals.
This post was edited by Tall T at 07:59:46 06/15/14.
Mike OH
06-15-2014 07:40:43
Could be a bad key switch. Could be I say, because that is an easy thing to check. Just jumper across the switch with a piece of wire and see if the spark returns. Don't forget to remove the jumper after checking or you may end up with a coil or point problem.
