TractorLinks.com
Show Parts for Model:
Re: Blade spindle replacement
Popgun
06-14-2014 23:06:58
Just a guess when you hit the object it may have bent shaft and put it in a bind. Maybe try heat and more hammering. On your N dont fix it if it anit broke. 30 hrs at 25 yrs is 750 hrs. You repack front bearings at 600 hrs I think if you need to do that. If you have taken good care of it changed the oil in it and the oil in the air cleaner I would not let anybody mess with it. All these Ns were well built all they needed to keep going was routine grease & oils . A little smoke is even acceptable. If it can hold 10 psi when oil is hot your in good shape, anything above that your fine. Use but dont abuse you got lots of seat time left with it. Age has nothing to do with it. Post back on your mower as we all like to see what happens and post anytime on about anything.
