Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
OT: Lawn mower
oldtanker
05-25-2014 06:55:00
OT: Have to replace the carb on our push mower today. Now I know someone is going to say rebuild it. It's 6 bucks difference in price between the rebuild kit and a new carb. By the time in add in a can of carb cleaner it's about a 2 buck difference. Heck of a notion. Throw away a carb just because.
Rick
W_B
05-27-2014 05:22:21
 Re: OT: Lawn mower in reply to oldtanker, 05-25-2014 06:55:00
I went to till my garden area and pulled out the front tine tiller I bought new in about 1992. Took a can of fresh gas down to the shed but checked the tank first, yep, still had gas from last spring in it. Set the choke, advanced throttle to full, pulled the cord and she fired and ran on the 4th pull. Sometime you just get lucky. Its a B&S 5 hp.
Mel-N-WV
05-26-2014 05:07:04
Did the same thing with a string trimmer. It hadn"t run in 2 years. $32 for a kit verses $38 for a complete kit. Changed carb and all gas lines, Runs like a new one.
Popgun
05-25-2014 13:35:14
Boy I must tell ya I have never had to put a new carb or rebuild on lawn care eq. I have 2 pre 1970 lawn mowers. a 1970 era K-Mart rotor tiller and a 40 yr old Ford pickup. The Ford card has been rebuilt 1 time. At the end of season I make sure all the gas is out of the tanks and flush the carb with MMO and pull it through the carbs by putting starter fluid in the cyls. and starting them. Never had a problem. Are you sure the carb is not gummed-up with old fuel that stays in over the winters. Just a thought or Im lucky
oldtanker
05-25-2014 18:27:46
 Re: OT: Lawn mower in reply to Popgun, 05-25-2014 13:35:14
Yup, forgot to drain the gas out. And this carb is metal, not plastic. 26 bucks for the carb, rebuild kit is 20.
Rick
Kevin in MN
05-26-2014 05:13:38
 Re: OT: Lawn mower in reply to oldtanker, 05-25-2014 18:27:46
So where do you find a carb that cheap?
Kevin
Popgun
05-26-2014 00:40:14
You arnt the 1st guy to do that and now it will never happen to you again.
s194387
05-25-2014 07:02:49
I bought a used lawn boy push mower last year at an auction. has a plastic carb on it.
TOM N MS
05-25-2014 07:04:20
 Re: OT: Lawn mower in reply to s194387, 05-25-2014 07:02:49
yep, those are definitely throwaways..and they usually do fine for a long time..
TOM N MS
05-25-2014 07:02:36
U did xactly what I would have done -- in fact did the same thing yesterday on friends weedeater. $18.99 for new carb.@ least $15 for a kit and then there is no guarantee...Now on an N carb it's a different story..
