9N axle mystery
Abbby
So just aquired a non running 9N for basically nothing. When checking things over I noticed on one outer axle that instead of the rivets you normally see there are bolts with double nuts on the outisde. Did someone try to do a seal replacement and drilled out rivets as a shortcut?
The rivets MAY have worked loose. Wouldn't be the first and only time that has happened in 70 or so years!
