Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
9N axle mystery
05-07-2014 10:08:00
So just aquired a non running 9N for basically nothing. When checking things over I noticed on one outer axle that instead of the rivets you normally see there are bolts with double nuts on the outisde. Did someone try to do a seal replacement and drilled out rivets as a shortcut?
Fuddy Duddy
05-07-2014 11:05:36
 Re: 9N axle mystery in reply to Abbby, 05-07-2014 10:08:00
One of mine had had someone to weld the rivets in place. Probably for the same reason yours were replaced.
05-07-2014 10:51:17
The rivets MAY have worked loose. Wouldn't be the first and only time that has happened in 70 or so years!
