Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: increasing current over time with electronic ignition
05-06-2014 19:21:44
not ONLY inline with the ignition.
If I put the headlights on, adds about another 5 amps.
I believe I am monitoring what is going into/ out of the battery, so everything. But when it's been running for a few minutes, and charged back up from initial cranking, current draw should only be from ignition system, as long as I have the radio and the headlights off, what else is there ?
05-07-2014 05:18:16
 Re: increasing current over time with electronic ignition in reply to FLAcharlie, 05-06-2014 19:21:44
I believe you are still 100% misunderstanding how your net charge / discharge system works.
draw it out so you can better see what is happening.
take a piece of paper. turn it on it's side, longways.
draw a 2" circle on the left, in the middle draw a 1" circle, and on the right, draw a 2" square.
now draw a line from circle one to circle 2, and draw a line fom circle 2 to square.
label circle 1, generator, label circle 2, ammeter, label square, battery.
now, on the left side of circle 2.. IE.. inbetween circle 1 and 2, draw a line down to a small 1/2" circle and label that lamps, scoot over a bit, but still between circle 1 and 2, and draw another line down and then a small 1/2" square and label that ignition.
here's how it should work... when running, generator making amps... amps are flowing towards battery, first stop is amps power ignition, then next stop is lamps, any leftover amps go toward the battery... crossing the ammeter makes it deflect positive, showing charge into the battery. Note the ammeter is not reading current used to power the ignition and the lamps, because those items were powered up the line before the ammeter.. thus current thru the ammeter is charge current only.
Now with tractor off, genny is not making any amps... so, with lamps or ignition on, only place to get amps is from battery.. thus amps flow from battery towards lamps and then ignition... your ammeter will deflect NEGATIVE showing discharge from the battery to both lamps and ignition.. in this state, the ammeter is reading the total load on the system as sourced by the battery.
that's why it is called a net charge / discharge system. net means leftover.. not gross. gross is the full output of the generator.. net is the full output of the generator, minus loads like lamps and ignition, result is net charge to the battery, OR discharge from the battery.
systems like this are wired with the battery, by itself on one side of the meter, and ALL other laods and charge devices on the other.
thus when running, with ign and lamps on, if you are seeing rising current.. you are seeing rising level of charge passing the ammeter to the battery.
