Trying to set up axle end play on 48 8N
Doug Pitts
New User
Tractor had extensive play in rear wheels. It is evident that there
were others before me attempting the good the bad and the ugly.
Bought new hubs, bearings, seals,etc. Upon disassembly discovered
one axle beyond repair. So starting from zero I instaled the left axle
using two thick shims and one thin plus gaskets and all seals. After
installing all components and tightening axle nut the end play in
and out is about 1/8 to 3/16. I have not installed the right axle yet.
I have tried to work this out checking the sources available to me
short of this post. J & D productions videos, I&T manual, Ford 8n
shop manual, Oldfordtractors.com, web. I am lost. Any help
appreciated.
OK, JMOR told you the truth and even posted a picture to clarify...
So what was the question again???!?!!?
You can't check for end play with just one axle installed as the two axles need to but together to set the end play. Follow JMOR's instructions and you should be fine.
Mark
