Wanted to share some attachment points for a Paulson loader I put on my ford jubilee.It is a full frame loader which is in two pieces. A piece of strap metal attaches to both sides of the frame at the top. Attachment points are under rear axles and attach using the 5/8 bolts which secure the fenders. Had to use longer bolts, two pieces of 1/4 2 inch angle to provide a different place for my anti sway straps to attach
The plate on too of the loader frame where it Attaches to the rear axle is part of the loader frame. It is pre drilled and holes match the holes used to attach the fenders. A heavy metal strap attaches to the front of the engine front support. Ends of the loader frame have threaded holes which heavy bolts thread into after going through the metal strap
