Hydraulic pan
SDC
New User
Noticed this weekend I had a hydraulic leak. Upon further inspection, found small cracks around the pipe plug drain. I have looked at most of the major parts places and have not found a hydraulic pan. Where can I find this part or how could the leak be fixed. Thanks.
On what model tractor?
If you're asking about an N, it doesn't have a pan. That's the pump base.
75 Tips
Yes it an 8N. So does the base separate from the rest of the pump? Suggestions as to fixes, really don't want to buy a whole new pump. Thanks.
" So does the base separate from the rest of the pump?"
No
a rebuilt pump will go for $400- 500. You can buy a lot of fluid for $400- 500.
But, if you need a pump, try these guys:
Jim Webb webbtractorATgmail.com.
John Smith smith8NATatt.net
Rod Mondor fltractorATpeoplepc.com
Replace the AT in the address w/ @
75 Tips
The base of the pump is Aluminum. If you take it to a reputable welding shop they can tig weld ip up for you. Don't over tighten the plug , I'm sure thats what fot you the leak in the first place.
Thanks. Could the crack be fixed, is the pan aluminum? I have indicated on the photo where the cracks are.
if it was a cast base.. then braze it.
if it is aluminum. then tog, aluminum stick ( dc ). or even alloy solder which is like brazing. but uses a zinc-copper-aluminum alloy rod.
