I think I figured out why my 2N over-speeds when I depress the clutch. On the outside it appears that the governor to carb shaft is too long and the vertical shaft is too short but they are the correct length. The governor works when I drive on my drill press using a soft wire wheel. But that only works when I hold the fork against the ball cup. On the tractor it is out of range and there is no way fork can be driven by the ball cup until the throttle is pulled wide open.
The problem appears to worn lobes on the fork . However I don't what the specs should be on the fork and I don't where to get a replacement fork. Would a shim be a smart replacement or is that just asking for trouble? Any ideas would be appreciated. Thanks
