8N serial numbers
Del
Hi I am haveing trouble figgering out what year my 8N was made. I have looked at the left side of the engine block, all I see are a 8N-B in raised letters and a small plate with # 328 1 stamped on it. What am I overlooking?
thanks Del
The serial number would be stamped in, not raised.
Are you looking at this flat spot?
Photo is from John Smith's website John's Site
There were industrial engines and replacement engines also,
so one of those may be a possibility.
Generally if they have a plate on the engine it is an industrial engine. Check on the right side of the block just behind the governor and see if it has a bolt on plate where a fuel pump could be mounted.
Mark
