Hydraulink Self Contained Toplink Cylinder
Fuddy Duddy
Any body tried one of these for a Top Link? Seems to be not any
thing more than an air shock built into a top link. Guess if you want
to shorten it you drop the 3 point down, open the valve and close it
when you get it to where you want it. Then the lengthen it, you
raise the 3 point open the valve and again close it once it where you
want it. Might be handy. But if I'm going to spend that kind of
money I think would get a real Hydraulic link. I have remote
Hydraulics on me 8N w/FEL and the 801. But anyone using one of
these. I'd be interested in how you like it?
Building one is on my list of things to do this summer. I've got a spare DAC lying under my bench I just need to come up with a simple valve (I like their pushbutton but may use a ball valve if that's all I can find in my parts bin) it looks pretty slick but I'm with you on power - it might be just as much work to put an electric over hyd pump on for activating/positioning that top link. That'd be just as portable from tractor to tractor so long as I have a quick disconnect power coupler.
I cannot imagine why anyone would buy one of those.
I paid less for my real hydraulic top link which is very useful when using some attachments.
Dean
Dean, I'd only run it if I didn't have remote hyd. If you're running a TOH belt or stinger setup or LiveThang hydraulics then a full hyd top cyl is a good option. For those of us without remote hyd capabilities the rapid adjustment of the hydraulink is quite appealing $200 for easy adjustability versus the cost of live hyd and a DAC toplink.
Those are the reasons I can think of that someone might want one.
FD,
Just build one.
I've posted these photos here before but if you have remote hydraulics and can weld even a little it's easy.
I paid $25 for the cylinder on Craigslist and scrificed a top link ($25?) for the swivels.
I would never go back to a screw type.
You can not imagine how much more versatile it makes a boom pole or back blade.
I've seen the post on these here before. Seems like some one said something about you need a pivot valve or maybe a check valve built into it. I have never seen one that will work on our CL. Time you buy a new cylinder you just as well about to just buy a Hydraulic top link made for the job. I have found that one would be almost a must when using a dirt scoop. Yea, I can stick metal together. My Father was a Pipe Line welder and he taught me a thing or two. I've seen good. And I wouldn't make the claim to be a good one. But I have out welded some who did make that claim. Welders tend to like to brag a lots. But a lots can't make the grade.
Those <a href="http://www.yesterdaystractors.com/Ford-3000_Cylinder-Top-Link_HTL3101.html" target="_blank">top links</a> are about $300!
I did search on CL for a month or two for the right cylinder before I found this one. But did find a good one - practically new but had been kicking around for a few years. I don't have a pivot valve (or whatever it's called ) on mine.
I figure the highest pressure an implement would put on the system would only be a few hundred psi. The remote valve is made to handle 2500 psi. It works fine without it.
Yeah, welding questions always get a lot of replys. Not sure why. I rarely weigh in on them even though I was a good welder back in the day. Give me some Low-Hy and I can still glue things together pretty well, not as well as I used to but good enough.
