waiting for repair guy for month decided to fix myself. picked up tune up kit at Tractor Supply.
before I swapped parts I tried to see where the problem was. not gas as I drained tank from bottom plug under carb.
tested with meter top of coil got +6volt. pulled plug wire and plugged old one in and cranked seen spark.
the key switch was loose so I tighted. I kept getting a clicking noise from solenoid swith, I also noticed the amm metter was going a little neg. and starter and wouldnt turn. I removed switch and put battery on charger.
Next day I reconnected the sol switch and put battery in. It started right up. now with the key on and with key off. It is great but concerned about the key switch.
wiring is old and the terminal thing is also original.
